DIMOND 468-030-LED WIDE LEAF LED TABLE LAMP IN NICKEL WITH NATURAL LINEN SHADE
22 Wide This Over Sized Leaf Lamp Makes A Statement Of Natural Beauty. The Organic Shape Of The Leaf And Each Of Its Veins Is Captured In Cast Aluminium And Finished In A Nickel Finish. The Lamp Is Finished With A Rectangle Shade In Off White Linen.
Features- Wide Leaf LED Table Lamp in Nickel with Natural Linen Shade
- Includes dimmable easily replaceable 9.5 watt 800 lumen screw-in LED bulbs
Specifications- Item Finish: Nickel
- Item Collection: Leaf
- Item Material: Metal
- Item Style: Transitional
- Shade/Glass Finish: Natural
- Bulb Number: 2
- Bulb Wattage: 9.5 watt
- Bulb Type: LED
- Switch Type: 2 Pull Chains
- Dimension: 21 x 22 x 10 in.
- Weight: 14 lbs
Price: 673.40
